Masina: Dawoo matiz 1998
Losing power
Mesaj de adanem »
I have MATIZ 1998 ,the engine was overhauled by local garage and all the required thing replaced. After completion we try to start .it start ,it hold idle but when we drive it lost power.
We checked all timing order .it is ok. we try to rotate the distributer and we achieved the engine breaking point but this point was out of the adjusting slote.
Is there any way body help me to solve this problem.
Re: Losing power
Mesaj de T U D O R »
Hello,
If you somehow removed the distributer files, try putting them exactly the same.
The position of the delta must be found depending on the engine response (ideal would be to put it in the middle of the hole).
Check to see if you have the whole coin in the split lid. Make sure the spark plugs are changed and spark plugs.
Good luck.
